Multiple System Build Please Comment... Honest Opinions
Spazilton
Alright so here is the Plan. Currently I am running only the system in my Sig. I sold off all of my other hardware last year that was even remotely current.
I did keep my IC7-Max3 and my 30 Cap P4 that does 3.8 on Air.
I do still have a coulpe of cases which I am going to use for this project.
I have a brand new P180 that I got a coulpe of months back with the Best Buy Deal.
My Goal is to have 3 strong systems. The New Intel for myself, The Opty 165 for my Wife, and the IC7-Max 3 for my children.
Myself will be primarly doing video encoding, some gaming, but when I do game I like everything on. Running a 2407 1900x1200 display..
My wife primarly surfs the internet but does Play World of Warcraft. I will also use her machine as a secondary encoding machine.
She is running a Dell 2005 FPW at 1680x1050.
The IC7-Max 3 will be for the kids, Basic Educational Games, will also do my Torrent Downloading, and File Serving. It will also be a secondary World of Warcraft Box for myself.
So Here is what I bought.. and the systems I will be reassembling. Please critique what I might want to change, and any other suggestions. I'm primarly looking for comments on the new intel setup, but comments on the other systems will be nice also :)
My wife will be getting the water cooling system until I can get my hands on the water cooling block for the 8800GTX. I dont see the great need to remove the water cooling until I have to. I ordered the conversion kits from DD so All I'm waiting on is the GPU block.
System 1: My Main System..
Antec P180, Until the parts come in then it will go back to the Lian-Li V-2000.
Motherboard
ABIT ABIT IN9 32X-MAX
http://www.newegg.com/Product/Product.asp?Item=N82E1681312702
I have always loved the ABIT intel boards, Been reading fairly good things, and seems to do very well.
Processor:
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M
http://www.newegg.com/Product/Product.asp?Item=N82E16819115003
Fairly Inexpensive now, I do plan on updating to Quad core once the price drops happen.
Memory:
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000
http://www.newegg.com/Product/Product.asp?Item=N82E16820231077
Confirmed High Binned D9, 4-4-4-5 @1000 2.2v Under $300.. Normally does 1100+ Seemed like a no brainer.
Video Card
EVGA 768-P2-N831-AR GeForce 8800GTX 768MB
http://www.newegg.com/Product/Product.asp?Item=N82E16814130072
Needs no introduction, Will be under water once the blocks come in. Was told a 2 week hold time on the 8800GTX blocks from DD.
Power Supply:
The custom factory modded 1KW in my Sig, No need to change, at all.
Misc HDDS, Boot will be a Raid 0 74GB Raptor Array.
System 2.
System in my Signature. Except the PS will be moved down to ..
PC Power & Cooling Silencer 750 Quad
http://www.newegg.com/Product/Product.asp?Item=N82E16817703008
Also it will be switched over to Air Cooling in the P180 for my wife... (She likes the looks of the case better :p )
Heatsink I picked out... for the Opty 165.. This Opty had no problem doing 2.90 on Air.
ZALMAN 9700 LED 110mm 2 Ball CPU Cooler
http://www.newegg.com/Product/Product.asp?Item=N82E16835118019
System 3:
Motherboard
IC7-Max3 Yes the Legendary P4 Board...
3.0C 30Cap Does 3.75 on Air
Have an XP-90 for the Heat sink.
I have a older pc-65 case for this.
Bought this for the memory..
G.SKILL 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400
http://www.newegg.com/Product/Product.asp?Item=N82E16820231012
Some reports of doing over 260... I dont mind running it on a divider, and I can lower the P4 Clocks. For under $80 can't go wrong..
And the Video Card...
BFG Tech BFGR78256GSOC GeForce 7800GS
http://www.newegg.com/Product/Product.asp?Item=N82E16814143046
Nice card, what put me over the top was the $50 MIR. Broght it down into the X1600s price range for a better card.
So with what I have bought do you think I will be able to accomplish my goals?
You bought it all already? Well then it looks great! lol. I'd keep the Lian-Li V over the P180, hehe.
So you want to run the E6600 @ 9 * 500? If not, go for some cheaper ram. Intel systems perform best on a 1:1 ratio.
Damn wish you would have posted a build suggestion thread first before you went and bought. I could have offered you some G.Skill ram for maybe a little bit more than what you paid that would for surely hang 1:1 with your cpu. Oh well.... everything you got looks great!
8*500 is actually my lofty goal. However I am hoping for at least 9*400 or 8*450. I went with the high binned D9 because if I do have to run them slightly slower than DDR2-1000, than I should be able to keep them 1:1 while getting the timings even tighter.
I do plan on keeping the Lian-Li, I have too much work in it, and I'm not thrilled with the layout of the P180.
Forgot to mention, that the P4 shoudn't have any problems with power, Its running a PCP&C 510 Deluxe.
