Multiple DvD Burners?Doable or Not?
JKownz
I currently running on Windows Xp Home Sp2. I am wondering if I could have Four Dvd/CD burners and make them run similtaniously. Also would I need a certain program or does Nero able to do this for me?.
well it also depends if you're doing batch burning or not. if ur doing batch burning, ie, the same cd/dvd on each burner uc an do it, otherwise I'm not sure if u can run multiple instances of nero to do seperate dvds/cds
Well the top will be the source Dvd and the other 3 will be burning it, Is that doable?
A DVD Duplicator is what you really want then. Contact SarverSystems here on the forum, he does this sort of thing.
