multiple CD burner
pashonic2nd
I need to make many copies of cds. I'm looking for a product that can burn multiple cd's at the same time or burn many one by one automatically. Anyone know where I can find these products, if so which is the best one?
hypermicro.com has a few, but they aren't cheap. also, if you have a frys electronics near you, i've seen them in the A/V department.
They are called duplicators. And they are pricy if you buy retail....however, it is easy to make your own.
Just search google for CD duplicator Controller card('cause that is what makes the 'magic') and find one that suites your needs.
Then just find or buy some inexpensive burners....the egg has some 52X for $30 shipped I think.....slap 'em in an empty tower in the following order....
CD-Rom drive(or burner)
Controller card
Burner
Burner
Burner....and so on.
You need a power supply(300W is fine)
and harddrive is optional(though the card will automatically make partitions to save the data so you can later create an additional image without having the originating media.)
If you go retail I suggest this one....Microboards Technology
Why, cause I bought from them my self(bought the one: to: one duper to see how they put it together) and I am near there location so I just went and picked it up to save shipping.:p
Anyway, google is your friend....use him/her(whatever you are into)
