Multi Display ?
markojeff
Hi all help out a noob here. I just hooked up a 2007 FP as a second monitor with my 3007. I am running it in portrait mode. I got that set up and working and rotated and stuff but my question is. I have the second monitor on the right of my main monitor and my cursor only spans over there if i go out the left side of my main monitor which is opposite where the second screen is. where do i find the adjustment to have the mouse go out the right side where the second monitor is instead? I am using a 8800 GTX -ac3 if that matters. Or is putting the second monitr on the other side my only choice if i want it to work that way?
Thanks
Thanks
In your display settings/properties just select the monitor labeled "2" and drag it around.
