muahha!
sabrewolf732
took this cpu cooler:
http://www.svc.com/kd-42cu.html
and cut off some of the fins, like so:
surprisingly, the stock clip fit the mounting holes of my 6800 when it is bent a little bit. I did manage to get a 90mm fan on it as well. Here is a pic installed:
ready for the summer heat :D
well, im running about 10c cooler than my stock cooler, also it is a good bit warmer now too. I also can benchmark at 380 now, whereas anything above 365 with the stock would pretty much lock up :D neodark I assume you mean the ramsink on the video card? its the stock one from the 6800 ref. cooler, has a heatpipe, cools pretty good
