tangokilla
- Aug 18, 2008
I've just upgraded to Windows 7 and I have installed the drivers given at: http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=131&prod_no=1063 .
However, there are no listed divers for Windows 7, so I did a little digging. Some people on other forums said to just download a Vista version and set it as that in the Compatibility mod.
I just tried that and the installation went through fine, but I see the icon on the bottom right with a red X through it. I can't launch Config Utils or the 'MSIConfig as Config Util.'
Also, when I go to CP and look at the Networks, it does not show any Wireless devices hooked up.
Any ideas? Do I need to buy a new device that is supported by Win7?
Thanks!
Thanks!
