MSI sent me a dead replacement mobo? Maybe?
finalgt
I just got my RMAd K8N Neo2 Plat back (after 3.5 weeks :rolleyes:) and I tried putting my system together. The first time, all the system would do is, the CPU and GPU fans would spin up briefly, and then turn off, and then the power LED would just blink once every few seconds. I figured I put the SLK-948U on wrong (which I did, because there' about 80 parts to the thing) so I disassembled the heatsink assembly, rebuilt it, and tried it again. This time, I just got a long, loud beep, and the power LED started doing the same thing again. Anybody know what could cause this?
Um, I tried it again and the speaker just BLARES a beep for as long as the system is on. Shit. What fucked up?
positive everything else is working correctly?
what do the diagnostic LED's say?
6800GT, 3 hard drives, Envy 24, one controller card, one dvd-rom, one cd-rom, two 512 sticks of Corsair in proper positions. Tried booting with the bare minimum and it does the same thing.
There are no diagnostic LEDs.
maybe since you put the hsf fan on wrong it crushed the core :confused: . Sorry probably not the case but i had that happen to an axp, not sure if it applies here. Plz dont flame
Uhmmm, just to check, you did plug in the 4 pin CPU power connector (the ATX 12V) that is close to the CPU socket right? Athlon 64 boards, unlike the Athlon XP require this in addition to the 20 or 24 pin power connection. Won't post without it.
Yes, I had the 4 pin CPU power connector plugged in. Turns out it was the video card; it's been sitting on my desk for three weeks, haven't done anything with it...but I tried switching the components out one by one, and the system booted normally with my old PCI Riva TNT2. Not sure how the video card ended up broken.
Here's a new development though: I had RMAed the motherboard originally because I flashed to the 1.90 BIOS, because I had been having problems with the memory frequency dividers working incorrectly and thought updating the BIOS would fix it. However, the 1.90 BIOS subsequently caused my system to be unable to boot whenever I had any peripherals plugged in; soundcard, controller card, etc. So I booted into DOS and flashed back to the 1.80 BIOS...but something went wrong. Apparently, I didn't make sure the boot block was overwritten with the new BIOS, so the flash utility "mixed and matched" aspects of both BIOSes, and I ended up with a system that wouldn't send a video signal to the monitor. It would boot up fine with no errors and run all day, but the monitor would just sit there blinking.
So, I specifically requested that MSI send me the motherboard back flashed with the 1.80 BIOS, if possible, because the 1.90 BIOS was the source of all my problems in the first place. I wasn't too surprised when I found out that it had been flashed with the 1.90 BIOS. So I uninstalled the soundcard and the controller card, downloaded the 1.80 BIOS from MSI's website, and used the MSI Live Update Utility to make sure that I flashed the entire BIOS correctly, Boot Block and all, which it did. It had no problems whatsoever, and then, on the reboot...computer running, no video signal to monitor.
I made SURE I did it correctly this time. I KNOW the BIOS has been correctly flashed in its entirety, Boot Block and all, and I still have the same problem as before. I think I'm done with computers as a "hobby."
seems like kinda crappy decision over MSI's shitty motherboard and shitty BIOS for it...
i have one too, so i know what youre talking about :rolleyes: im done with MSI for good.
I have a "similar" problem. I have a k8n neo2 plat and I've been using it with a 6800gt for a while without any issues.
I tried a 5900nu and it seems to boot but no video signal. Both cards work in my AN-7.
I haven't touched the bios its version 1.8
