MSI RS480M2-IL audio problem
DaCoOlNeSs
ok, so when I don't have any front panel audio plugged in, the front port doesn't work for anything. but when I have front panel plugged in, it works fine. I cant do anything because I dont have any audio! help!
to clarify, if I don't have any front of case ports plugged in, the front channel when plugged into the back will not produce sound. thus leaving me with the 3.1 from the rear and the middle.
I am using the AC97 codec if that helps any.
