msi gtx 670 crashing help
Erudito87
my problem is that it has recently started to crash/restart computer whenever i play games for more than 20 minutes i think i need to flash the bios on the gpu but i have no idea how the msi live update has some sort of warning on the download page saying to only use it with msi mainboards so im stumped plz help my vga bios is 80.04.19.00.0B is this known to have problems etc? thx in advance
Score: X2516 (72 FPS)
Submitted by outwar6010 (anonymous mode) on October 28 2012, 9:01 pm
API 3D: OpenGL 4
Graphics score: 4582 points (100 FPS)
PhysX score: 1927 points (96 FPS, GPU PhysX)
Combined score: 1326 points (26 FPS)
Duration: 130000 ms
Resolution: 1920 x 1080
Anti-aliasing: X0
Window mode: fullscreen
Primary renderer: GeForce GTX 670/PCIe/SSE2
OpenGL version: 4.2.0
Graphics drivers: 9.18.13.697 R306.97 branch r30641-13
Number of GPUs: 1
GPU 0 - NVIDIA GeForce series (10de-1189) - GPU clock: 0 MHz - Mem clock: 0 MHz - Max GPU temp: 79 °C - Max GPU load: 99 %
CPU: IntelR CoreTM i5-2500K CPU @ 3.30GHz
CPU speed: 3310 MHz
Operating System: Windows 7 64-bit build 7601 Service Pack 1
Crashing after a short period of time- sounds like you have an overheating issue. Watch your temps over time, and take a good hard look at the card's mounting.
If it is a heat issue, it means that the HSF is not properly mounted; you can either try remounting it yourself, or RMA it back to MSI for a replacement.
thx for the quick reply this only started like 3 weeks ago i just checked the k mark combined test leaderboard and someone with similar rig achived a similar score with 20 degrees lower so it must be that. i have the MSI N670GTX-PM2D2GD5/OC which looks like a bitch to open etc plus im not that confident that i could do it im going to contact the place i bought it in the morning thx for the help
