Fuzzy Logik
- Aug 16, 2001
Ask away ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Some things u will want to consider
Vista is only being released on DvD - no CD.
You cannot upgrade install Vista unles you are running XP SP2 - otherwise it's a clean install from the DvD.
With Dual boots, install your legacy OS First! - otherwise, for example, if you install XP after Vista it will replace Bootmgr in the MBR with ntldr, and vista will not load on ntldr, it uses bootmgr to locate winload.exe to load Vista's kernel.
If you screw up - use the Vista DvD to boot into Win RE -(repair actually works in Vista ) and use bootsect /nt52 D: ( use whatever drive letter the XP partition is on.)
This may be fixed later in patches, but if you install Vista on the D partition ... and you are in vista, it names your D partition drive letter C... aint that a B. It's still on the d partition.
Readyboost helps take the load off of small data chunks needed to start certain applications or other proceedures that would plausibly take a hard drive longer to locate. Will need some tests done to really see how well it preforms.
I tried deleting system32 but it won't allow certain things to be deleted regardless of permissions or read only attributes. Everything in the folders is gone afterwords... yet Vista loads just fine. I guess Vista just wants winload.exe to load the kernal and the kernel must be the majority of the OS.
It's pretty difficult to destroy this OS.
Aero Glass and Flip 3d are cool features.. but it's not the only reason to use Vista.
That's just some basics... if you have any questions or more technical issues, i'll be checking this thread frequently.
