MS intelli explorer 3.0
mooseboy84
is there anyway to clean this mouse?
the middle scroll seems to be clogged with dirt and doesnt scroll well. is there anyway to pull off the left and right clickers so i can try to clean it? when i use the scroll in the middle, the articulation is not very accentuated. plus the grip is worn down from using the mouse for 2 years. when i play games its hard to change weapons fast because it get stuck and messed up. is there anyway to clean inside, or do i have to my a new mouse.
Quite easy really
1. Get mouse, phillips screwdriver, soapy water
2. Open mouse
3. Remove circuit board
4. Put plastic parts in soapy water
5. ...
6. Take out, rinse off, let dry
7. ...
8. Profit
You can take the mouse apart by removing the fours screws located under the glider feet on the bottom of the mouse.
Originally posted by freecableguy
1. Steal the underwear.
2. ???
3. Profit
What's step 2?
I don't know....I don't know....
:rolleyes:
You should be able to take the mouse apart - heck, someone DID have to put it together, right?
