Eyeball Kid
- Jan 31, 2002
I can't get my MS FF2 joystick to keep it's settings in XP. It used to work ok, it seems some recent xp patch or other has bombed it. I go into the settings for the stick, set forces to medium, stick resistance to medium, and all is ok until I press any button to test the feedback, then everything is bumped up to high again, even though the setup shows medium selected. I've a feeling it's an activex problem, I notice in the install files there are activex controls called recorder.ocx (Which now crashes every time I try to run in in the control panel, used to work fine) and forceset13.ocx, among others. Anybody know of a workaround?
