Ok so I'm trying to install windows onto a second computer I got and Its not going well at all.
When trynig to install windows 2000 I get to the part where it copies the installation files onto the harddrive but then says that it cant read any files from the cd. I tried a few other installation disks and the same result. I even tried other cd-roms but to no avail.
Its strange that it reads the disk fine until it copies the files over, same thing happens with windows 98.
I read something about coping the files directly from the CD onto the harddrive and load setup after booting from a Win98 boot disk. I tried this but it just stop working after running setup.exe from dos.
As a last resort I tried installing windows xp onto the harddrive from my desktop pc. It went well until i tried booting into windows. I get a "Invalid system disk, Replace the disk, and then press any key" message. I guess there is no boot file or something. I'm clueless and I would love some help since I've been dealing with this crap for a while now. Can I get windows to boot after installling it from another pc?
Its a PIII celeron 800mhz cpu sitting on some generic mobo.
help is appreciated
help is appreciated
