Mouse Bungee
I use one. I recommend it, as long as you raise the bungee on to a higher surface.
I have one, Love it. The only thing that could be better is that it should be heavier, even though it has never moved while I was gaming. I also looked at that site, but if you try to buy from there, firefox says that the site's security certificated is invalid. I got mine from either buy.com or amazon, I forget. My mouse wire always got in my way, so this thing rules. It's pretty expensive for something that holds your mouse wire out of the way. If you have the cash, get it. Otherwise, a do-it-yourself solution would be cheaper.
