Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
How about a minature force field so you can put it anywhere you want with no fuss or muss? Oh shoot I forgot it is only 2005. So what is wrong with a rad box?
its hard to compromise between portabillity and having a external wc set up. My recomendation, buy a 1 X 120 Rad, there are a ton of ways you can set those up in cases internally. BTW I wouldn't travel with a wc set up unless you check that system ALLL of the time... its not fun trust me.
Ok... so you don't want to mount it on the outside because you ship your case around a lot. So then why don't you mod a bit and mount it on the inside like I had suggested?
