I have a bundle of 6 motherboard cpu combos for super cheap .ill sell the whole bundle of 6 mobos for $175 + shipping .
2x 2800+ sempron 64 with gigabyte k8vm800m motherboard
2xSempron 2200+ cpu with gigabyte motherboard
1x 1800 + amd cpu with gigabyte motherboard
1x 2400+ sempron cpu with gigabyte motherboard
All mother boards were pulled form working environment and are fully functional.
I also have a complete pc in a small htpc case sempron 3000+ cpu gigabyte mobo 1 gb ddr memory 80 7200rpm ide hd and power supply does not have a cd rom in the unit. will sell for $75
2 x Orinoco ap2000 wireless access points without power brick and 2x 802.11g radio cards in each ap . $50 a piece
5 x 80 gb 7200 rpm ide hard driver $25 a piece .
**************************************************************** 2x VIA C3 1GHz/ CLE266/ DDR/ A&V&L/ M-ITX Motherboard EPIAM10000G CPU: VIA C3 1GHz EBGA Processor, w/ fan Chipset: VIA CLE266 & VT8235M Memory: 1x 184pin DDR-266 DIMM, Max Capacity 1GB Slots: 1x PCI Slot IDE: 2x ATA-133 Channels Audio: VIA VT1616 6-Channel AC'97 CODEC Video: Integrated VIA Unichrome AGP Graphic Controller, w/ MPEG-2 Accelerator LAN: VIA VT6103 10/100 Base-T Ethernet Controller Ports: 4x USB 2.0 Ports (2 rear, 2 by header); 2x IEEE 1394 Headers; 2x PS2 Ports; 2x Serial Ports (1 rear, 1 by header); 1x Parallel Port; 1x VGA Port; 1x RCA Port (SPDIF or TV out); 1x S-Video Port; Audio I/O Jacks Power Connector: 1x 20pin Main Power Form Factor: Mini-ITX, 17 x 17 cm Package: Retail RoHS Compliant These little tiny boards have a 1 ghz via cpu built in and are perfect for a carputer or any small computer build. I have used them for Carputers and for small modded pc's . $50 a piece . I have a small 1u rack case for these motherboards and power supplies I will throw in case and ps for an aditional $25
