-=PESTILENCE=-
- Jun 10, 2004
So i was just doing some audio editing for my band, and it seems like my board shorted out. USB stopped working and then a few seconds later the computer shut off. I rebooted and the motherboard had no time and date set up. It started to boot and says "raid controller 1 initializing" and then it says no physical disks. It boots into windows just fine as that was on a separate drive. The raid drive shows in windows, but I can't access it. Do you guys think all the data is lost? Or is there some way to save it? It has a ton of important edits on it and I haven't backed it up in about 2 weeks...
I would hope that since the disks are in the same state, there must be some way to salvage the data.
