Motherboard problem? I guess
malice8691
My pc started getting really slow but not all the time. It seems like it runs fine untill you try to load something. It doesn't do it every time consistantly though. I have an abit ai7 (socket 478) board. I run a 1.8 ghz intel at 2.3. Right now i'm running everything at stock speed (failsafe defaults in bios) The problem presents like this: I open a program like nero for example. It can take over a minute to open. The hdd light is lit like its busy loading something but nothing happens and finally after a minute it starts and seems to work at normal speed. Its not limited to nero. It could be any app. The browser, windows explorer, anything. So my first assumption was my os was just hosed. I formatted and reinstalled. The problem is still there. So then I assume it has to be my seagate drive because when it happens I can see the hdd activity light on.I remove my sata seagate and replace it with my sata hitachi deskstar and reinstall. The problem is still there. I ran memtest to chek my memory (corsair) It passed no problem. I ran sisoft sandra and started doing some of the tests. CPU test passed no problem with speed right where it should be. Hard drives passed the speed test as well and did not show any slowness. I have booted with the cdrom disconnected and I ran a speed test on it and it passed as well. I have come to the conclusion that it has to be the mb by process of elimination. I stated that I have reinstalled the os and its pretty clean right now. I have the latest drivers that I downloaded from abit. I run zonealarm and kaspersky av and thats about it right now. any ideas?
control>system>advanced>performance , settings tab>advance tab and then see if you have the right amount of Page file , is it enough?
Also system tools and disk defragmenter.
I agree that the problem may not be that you have enough page space. Try increasing the size, and then see if the problem persists. Usually when a system just seems to randomly slow down, its a problem with memory somewhere in the system (IME).
I already said that to him
OK. Guys I fixed it. Was my bad. It turned out to be a power problem. I had my hd plugged in on the same line as my video card. The card was sucking up too much power. This is why the windows desktop was fine until I had to load something. It also explains why I could surf with no problem but running games caused problems. I didnt think I couldnt share the power line . I have an enermax 430 w supply. My video card is an evga 7800 gs. I guess its just a beast.
