motherboard fan header
polonyc2
I have 7 total fans in my case at the moment and was wondering if using up all the fan headers in my motherboard is a good idea?...would connecting some of them directly to the PSU be better?...meaning does it draw too much power from the mobo itself if too many fans are plugged in directly?...or should I just use the fan headers on the board if I have them?
It's better to connect fans straight to the PSU unless you have some particular reason to connect them to the motherboard. Technically the motherboard should be capable of handling the fans, but it's best not to put it under that load.
I prefer using the motherboard fan headers whenever possible, as I don't actually use Molex plugs for anything else in my system, plus you get monitoring and sometimes adjustment. You don't want to use huge power-sucking fans, but I've got all the fan headers on my X58 board filled with Yate Loon slow 120mm fans, and have had no issues.
For a truly accurate answer, you'd have to compare how much the fans draw to how much the board is specced to provide via the headers (which I don't know that I've ever seen).
