Hello, I have two quick questions.
I have a lian li PC75 case, and for the Power LED wire is a three pin connector, but my motherboard (Tyan Tiger K8W) requires a two pin connector.
1) What would happen if i connect the +V wire to it, and left the ground wire off(right now, that's the only way it would fit)?
2) is there an adapter that could turn a 3pin connector into a two pin? I want to avoid any DIY wire jobs or suturing.
Also, my case came with no instructions, and for the connectors to the Power LED, Power Switch, etc... it does not say which are +V and which are -V.
Most cables have a white cable, with a colored cable. The speaker cable is red and black. On the black plastic connectors there is a little arrow on i belive the white wires (not sure which on the red and black one). Does anyone know for sure which is +V and which is -V(ground).
~Thanks
~Thanks
