If you are referring to Windows ICS then no, you cannot use static address's for it. This is one of many limitations that the Winows ICS has.
Why would you need more than one ICS machine unless you are connecting to multpile providers? If that is the case you are better off buying a full fledged router/fw for that or ever better get familiar with linux and build one
