I found out the photoshop does not work, using correct monitor profile in a dual monitor setup. It uses the first monitor, main screen only. You can fool it by changing the profile in the my Laptop to the calibrated 2nd monitor.
I never knew this until recently.. all along I was using my Laptops profile to edit pictures on my 20" CRT, now wonder I have crappy images.
My question is if a monitor that has internal calibration, the profile is done in the monitor instead of the card, Laptop let's say, I should not have a problem with PS when using it on the larger monitor.
I am talking about a NEC 2490wuxi or a Eizo cg243w monitors which have internal calibration..
What are your thoughts on this?
