Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
it shoudl be right click desktop, properties, settings tab, advanced... should be display tab, and you should be able to set it to TV there, if everything is pluged in. (you may want to drop your resolution b4 you do that)
good luck and happy moding (you may want to ask a mod to move this to gen sofrware, or vidiocards, or something)
go to desktop management on that screen.. click enable nview desktop manager.. then apply and ok right click desktop then click nview properties and set it up =)
there's a lot of tabs under there I believe once you enable it the second monitor may show on regular desktop properties.. but you may have to look in the nview properties.. go to Nview then "display settings" Also you may want to check out the wizard. . I don't have my 2nd monitor present so I can't remember the steps exactly after what I've told you.
