Ok background first build will be end of this year, will use the highest I-7 avail, maybe spring for a 6 or 8 core CPU if under 750ish. I'll likely pick up high-end maxwells x2 and maybe more. Price for total build is probably 4-5k. I have SSD, PSU, 32gb memory. Etc.
So to the monitor questions. I was thinking dell p2815q's x 3-4, but the more I find out about them they seem to have real limits for gaming, 30hz and that means no 3D down the road. So then I looked at the Asus vg248QE, which at x4 still gives nearly 2kx4k resolution assume ill mount them vertical. Maybe by year-end we will have high hz 4k? But even then 4x4k may not be able to be driven to a framerate that allows 3d anyhow. So is my best bet the 4xAsus? Other thoughts? Games to be played varied I like elder scroll, civ, driving games like need for speed, various dungeon crawl and strategy games. Not that I won't buy a few new releases.
Anything else you need to know? Oh yeah I'll be oc'n the processor on air so expect 4.2-4.5ghz.
Thanks for your opinions!!
Just found the 27 in benq version of this monitor that might. Be viable
