Monitor Mount Help
EndersShadow
I am looking to possibly purchase the ASUS VW266H monitor. I would like to get a nice mount to go with it and am having tons of trouble finding ones that will work. The overall height of the monitor is 18.18 Inches. I also plan to purchase a separate single mount for my 19" monitor so I can rotate it landscape for use as a secondary monitor.
I looked for dual vertical mounts thinking I could use just one of the mounts and then have enough height vertically to mount it. If anyone has experience with these mounts please let me know.
1. Atdec Spacedec
2. Dual Vertical Desk Stand
I also found a couple of "TV" mounts that also "might" work but once again I am not sure.
1. 10''- 24'' Plasma/LCD TV Double-Arm Desk Mount (Silver)
2. 13''- 24'' Plasma/LCD TV Height Adjustable Double-Arm Desk Mount (Silver) - MD2430-PB
3. 10''-24'' VESA Arm LCD Desk Mount - DLB371
I only found one actual desk mount for a 25" Monitor, but I am not sure if it has the height needed for it. Sanus VisionMount MD115-G1
Any help would be appreciated. I didnt think it would be that hard to find a mount :(
After doing lots of looking, the only mount I can find that isnt insanely expensive is this one....
http://www.amazon.com/gp/product/B0012S3920
I think I dont have a choice but to get it. I will have to purchase a separate single mount for my other 19" monitor which is fine.
Have you looked at Monoprice? They carry a lot of cheap mounts. I've never had quality issues of the many wall mounts I've bought from them.
Yep..Go Monoprice...
I bought a swivel arm mount that I have on the wall near my bed..DVI Cable running from HTPC..
Pretty impressive to wake up to...and ladies love falling asleep to pron right in their face lol
