There is some debate about that....Colorvision sells a "Spyder TV" package but the software will only recognize the "TV" colorimeter even though it appears to be the same as the one used for all of the monitor calibration packages....whether it really is the same is what the debate is about. It is possible to use the regular Spyder 2 colorimeter with 3rd party software to calibrate tv's....but it's more difficult since you will need either a test pattern generator (big $$) or a dvd with test patterns and the 3rd party software is generally much more complicated to use than the integrated "follow the prompts" Spyder TV package. Check the avsforum calibration subforum for more info.joemama thanks for clearing this up for me.
kam03 make sure and check the link I posted its where this is discussed in depth.
joemama is this hardware good enough to do Plasma and LCD TV calibration?
