Monitor cable length
audi0slave
Hi, I need to run a 2nd monitor from my PC to my HT rack, and would be using a DVI to 15-pin RGB adapter for this 2nd monitor.
Will 10-15m run of this cable be possible without signal problems?
Thanks.
Thanks.
You will definitely notice a signal degradation. Try to check if you can find a vga amplifier along with the cable to boost the signal.
