Monitor all temps?
esCo_
I see people saying their loop is to hot. How do you go about monitoring your actually water in your wc loop? Would Aida be a good program for this? I currently use AI Suite II and Real temp to monitor my cores, voltage, and fan speed.
Most people get one of these... Temp Sensor and stick it on the res.
Monitoring the actual water temp isnt really necessary though.
What do you plug this Temp Sensor product into? Is there a standard pin header configuration?
Bonus question: Does it plug into Corsair Link?
