Modular Water Cooling?
Fps_Rory
Does anyone know of any good I guess you would call them modular water cooling kits. The ones that fit into your drive bays and their all self contained. Thanks.
the one's that fit in the bays are worthless. Might as well use a big HSF.
For "modular" the Kooliance external is a good choice for a first time W/C job.
Or maybe (if you can squeeze it in) the Big Water as it gives ok results and can pick up one for around $150.
