Mobo Trouble
ssyidos
Ok i bought a new comp. that has a MSI K8n Neo2, mobo and amd 64 3000+ venice processor. when i got it all put together and pushed power. it wouldnt post, so i called my friend over he said i have processor in wrong. and we did some tests to see if processor got fried or nto. so i sent back the one i had and got a newone.. but the new processor arrived and it still wont post any ideas on what could be my problem? ram type i have is patriot 1gb DDR. graphics cars Lead Tech Geforce 6800 GT, rosewill 500w ps.
gee-- are you sure the PSU is good ? have you tested all the other patrs of the pc ? ram, videocard ?
did you check all the connections and make double sure the videocard is fully in its slot ?
how could the cpu be inwrong ? they only fit in one direction ? you might need to re-seat the CPU.
check the DIMM"S make sure their fully in ths slots and in the slots the right way. make sure all teh power connections are fully plugged in--
if still a no-poster-- try one stick of ram-- and try one good stick of ram a diffrent slot if it don't boot up until you run out of slots.
sometimes the MB can ground inside a case and make a short -- i have a test stand to test MB's on before i install them.
you can remove the mb from the case then re-assemble the computer - on a cardboard box top or any non conductive and non static surface.-with just the ram--cpu and heatsink and videocard.
get a PSU that your sure works --attach it to the bare-computer and see if it will boot and give video--if you have a spare MB you can test the component parts in it first. allways handy a spare MB--LOL..
some of the newer core revisions need a bios flash to even boot up--however i have found that to be rare.
after checking all this stuff out and the MB still just spins the fans and no video through the agp or the pci--you got a DOA motherboard if the other stuff checks out good.
Try doing a BIOS Flash update because some mobos will not use certain types of ram/processor since the BIOS is outdated. Make sure you didn't crack the processor core while installing heatsink.
well i forgot to lift up the clip that holds the processor in place when i went to put the processor in. so when i booted up the processor wasnt clamped down. my theory is i fired the old processor and maby the mobo's processor soket when i did that. but if ya have another theory lemme know. also i tried the 1 ram stick idea and both had no post. but that was with the old processor.
humm-- you say the cpu was put into the socket --yet the lever was down and the socket was closed ?
well--i have never seen that done--but it would look like the cpu's pins wouldn't go down far enough to make contact--?--were the pins bent when the cpu was pulled out ?
i can't say what would happen if the cpu did make contact with the socket leaver closed--that might shourt the MB and the CPU ?--but i have no experience in that area-- if the other stuff tested OK --ram-psu videocard --try the new cpu in the socket .
do you have a good MB to try the "old" cpu in? if you do --try it and see if you get a boot. :eek:
more problems. okies i got new mobo and new processor. i got it to where it posts but now when it does the screen comes up all messed up. like the graphics are messed up bunch of areas squared out and all that. but my graphics card works fine cause i tested it in my bros comp. also it will not ready my Harddrive and i tried several diffrent IDE cabls so far. any hints as to what my problem might be and how i could fix it? plz help.
my friend was building a computer for his mom and yesterday he brought it over and it had the same problem
We looked at the pins on the cpu, all looked straight, reseated still no post
tried 2 different video cards, 3 different monitors, and put the 1 stick of ram in all 3 spots
Will try taking it out of the case, pretty sure the board was elevated off all of the case but who knows
One other possible thing is the CMOS battery is kaput
he bought the mobo off of ebay though, so who knows
I see in the forums once in a while that people have issues when they are using a PSU from Rosewill, not that it might be your issue but you might want to find another PSU to test out
dont think its my powersupply, it just seems as though something ist compatible with the motherboard, or other hardwhere. cause it does post but the screen is so messed up i cant even seen anything on it from being blotched out and crap. any other ideas as to what it might be? im thinking its ram cause it might not be compatible with the motherboard but i dunno. please help me.
It isn't his PSU since the rails test fine and steady for minutes on end in the BIOS. BTW, I am the friend that went to help ssyidos out.
Anyway, I think what happened was that the improper CPU installation fried both the chip and the motherboard (or at least the socket part). It may have also damaged the video card, but this could have been defective to begin with. I'll talk more about the latter later.
Well, with a new motherboard and cpu, I got the system to POST, but there was garbled crap on the screen again, just like before with the defective cpu and motherboard. The time before, it POST'ed once or twice, then it wouldn't anymore. With the new cpu and motherboard, it POST'ed without trouble - there was just garbage on the screen. Seems like a classic video card problem, no?
I didn't want to attempt a BIOS flash because the system seemed unstable.
I figured that MAYBE it was a short or bad memory, so I put everything on a piece of cardboard to eliminate the possibility of shorts. There was still garbage on the screen. I also swapped out the memory for 2 different brands. No luck.
Here is the strange thing. The first time this happened (with the damaged hardware), I tested the video card in another system. It worked fine - there was no garbage. I tested the card again after the arrival of the new hardware (in the same testing system) and I got garbage. Weird, huh?
So yeah, the problem was the video card, perhaps all along. It is possible that it was damaged in the process somehow, I suppose. Maybe it is just finicky. Who knows. All I know is that ssyidos has had a bad stroke of luck. Hopefully after he gets a replacement for the defective card things will be fine.
