Captain Colonoscopy
- Feb 19, 2004
I have a problem with a friend's computer. Here are the specs:
MSI socket A mobo
XP 1600+
256MB generic PC2700
GF2 MX400
WD 40GB HDD
Generic NIC
Generic Modem
PowerUp 350W PSU
The machine gives a series of two long beeps when turned on and will not POST. The monitor does not go into sleep mode after left running. I have swapped the video card with one that is known to work which did nothing for the problem. I have also swapped out the PSU and CPU with confirmed working units and the damnable beeping persists. The only other thing I could think of is the memory but I cannot swap mine into the system because I am running registered dimms for some stupid reason. When I popped open the case I was treated to one of the dirtiest interiors I have ever seen. Cat hair and dust caked onto almost everything. I am starting to think that the mobo is toasted. Is there something else I should check here? Your insight would be greatly appreciated. Thanks.
MSI socket A mobo
XP 1600+
GF2 MX400
WD 40GB HDD
Generic NIC
Generic Modem
PowerUp 350W PSU
