Mobo shorting....Grrrr!
cyberslag5k
I suppose this is a problem I've always had, but it's never been this bad and I'm desperate to fix it.
My computer keeps shorting out, particularly if bumped, in the form of it rebooting and occasionally not re-posting. If it happens to not be posting, I have to sort of poke and prod things until I can finally get it back up and running. This tells me there's some kind of contact [i[somewhere[/i] that's causing a short. If you guys think it's something else, by all means, but that's where my money is, especially since pulling on one side of the motherboard a bit seems to fix it most frequently.
It started happening particularly bad when I relocated my computer from once side of my basement to the other, so maybe I bent the case or something, but I don't see any contact anywhere.
So, I'm attmepting to remedy the problem. I've attempted reseating the motherboard and video card multiple times, which doesn't seem to help. I have no extraneous risers, only the standard 9 in the 3x3 formation. I was thinking maybe the problem was me not using the little paper washer things that come with most mobos, but apparently those are only for the screw heads on the upper side of the motherboard, away from the case, so I don't know about that any more. I have a bunch of those plastic risers, I could try using those, I suppose.
I just hate this so much, can somebody help me out? I'll be happy to provide any additional information, as well as clarify anything as needed.
Thank you.
Take the whole board out and re-install it. See if that fixes anything (and you can check for any dents that may be present on the part of hte case underneath the motherboard)
Thank you for your reponse, StealthyFish.
Sadly, I've tried that multiple times. Also, there don't appear to be any dents or anything, and the risers are on a plate separate from the side of the case, so any damage would have to go through that.
Check all your molex connections. You might not be shorting something, it could be the opposite way around... you might be losing power to a device. My computer hard reboots when I had a faulty Molex extension (to a HD) installed.
if you think it's your case, go take a wood block or something, and set your motherboard and all the components on it and run out of case. If it runs fine, then something is touching the case or the screws.
if you have any extra stand-offs, that will do it. also, check any wires near fans. they can rub up and over time wear down the insulation, causing it to short. also check for loose pins in your molexes. make sure that your 4 pin 12v(p4) connector is in snug and all pins are ok.
I pushed in all the molex wires and it seems to be working so far (about 20 minutes), which is certainly better than it used to be. It hasn't been bumped or anything (I'm almost afraid to), so I'm not sure if the problem is completely taken care of, but so far so good!
Thanks a bunch, guys!
