Mobo probably dead?
Caff
Ever since last night, my computer was acting up, but I thought it was only a faulty USB port (as at that point, USB devices were acting strange.)
Then by this morning, my computer suddenly crashed.
When I reboot, most of the time, everything turns on, fan and everything, but nothing else happens. A few times that I tried it, I actually managed to get to the CMOS screen. However, after a while the temperature monitor started acting up (it would say 80C, then all of a sudden after rebooting would say 51C. Sometimes it would just say NA/C for some reason (assuming the sensor was having issues.) Also, a few times, the POST would stop halfway through without any beeps. Another thing was when loading Windows, it would stop 75% through, or have random corruption on the screen. On the one occasion I got into Windows, everything worked fine until I plugged in a USB device. Then it blue-screened.
I'm guessing that it is the motherboard that is dead, since all these little problems seem to be things that are related to the motherboard in some way. I'm about to try the PSU in another machine to see if that is the problem, but it seems unlikely, given that everything is powered up. I tried to run memtest, but by that point, the computer is no longer capable of properly booting up. When I press the power button, everything powers up, but it doesn't even POST or do anything else.
I agree they all relate to the mobo but all of this also goes through the ram and chip so dont just throw your mobo out just yet? Id recommend first testing your ram in someone else's machine. But im a newb...
Were you overclocking?
The first thing you want to do is clear the BIOS (CMOS).
Your error indicates that the cpu fan may not be turning. Is it on the right connector? Some mobos need to see an RPM signal to powerup fully.
What heat sink are you using? Is it a retail HS? Did you use AS5 or white thermal paste? Are you using a pad? If you are using a pad have you ever removed the HS? If you have you should buy a new pad for under $2 and replace the old pad.
What happens with the side cover off?
Nope, was not overclocking. Comp has been running in this configuration for more or less 2-3 years.
Heat sink: volcano 7, using the pad I think. Haven't removed the HS since installing it a year or two ago. Yes, the CPU fan is turning, I checked it when the cover was off.
Side cover off doesn't really do anything except help me see that everything is running.
It seems that the sensor for temperature is simply broken. The fan sensor was working at the time I checked the temperature (few hours ago) when the temperature had those strange variances of 81C and 51C between reboots.
I have just installed the PSU in another computer and it works fine, which means that all that is really left is to try the RAM in other machines and also check if the CPU is having issues.
By the way, there is no beep code at all, unlike the usual when I had dead ram before.
Hmm, I've gotten my CPU off the mobo and it looks like the pad has melted slightly around the core, instead of just on top. This isn't supposed to happen, is it?
