mobo for X1900XT
what mobo should I get, I am hoping to get the powercolor X1900XT. please, I needs an answer ASAP, thanks
**EDIT**
Do I need a special mobo, or will an ASUS A8N5X be fine?
Any pci-e mobo with a x16 slot should work for you. The one you mentioned will work fine. If you plan on doing some serious overclocking might want to look elsewhere...
