mobo advise
Focusun
On the advise of enginurd and others, I am foregoing an expensive Asus board and have pretty much decided on a Gigabyte GA P-35-DS4 rev 2.0. This will be for a new (first) build. Q-6600 4 gb ballistix, lian li 1000 P2, Gigabyte 8600 gt, scythe cooler, 2 seagate S2 drives, Corsair hx 520, various new peripherals. My question, Does anyone have experience with this board in a similiar set up? If I overclock, it would be modest, and not much gaming. Mostly used for photo work in Photoshop & Xara. Thanks
I have the cheaper version, GA-P35-DS3R... it works like a charm with my E6750 (got it to 3.8Ghz!). I'll upgrade to a quad around April 22nd or maybe July 22nd, hehe. :D
Enginurd - Thanks for the input. One other question. Will this board play well with the Scythe SCINF - 1000 as far as size and adequate room? Would you recommend stock fan or S flex?
This will be going in a Lian Li 1000 P2.
I'd actually recommend the Tuniq, Thermalright Ultima 90, or Thermalright Ultra 120 eXtreme instead of the Inifinity.
I really like the performance of the Ultima 90 along with how small it is. Though, I'm not sure if it will fit on the DS4. The MOSFET heatpipe portion might get in the way, but from the look of the installation instructions on the Thermalright website, it looks like it will fit fine even with the heatpipe there.
The Infinity's size is similar to the Ninja's, just more rectangular, which should make it slightly easier to install. I would, however, recommend picking up a Thermalright LGA775 Bolt-Thru kit (~$7) instead of using the push-pin fasteners. The stock fan worked well with my Ninja, but it is a sleeve bearing fan, which isn't as reliable as an S-FDB fan like the S-Flex.
Enginurd - Are you saying the Thermalright 775 bolt thru will work with the Scythe 1000?
Where do you find them?
will they work with the scythe as well? Thanks
Yup... its just a backplate and spring screws. You'll need to remove the plastic push-pins from the original mounting bracket of the Scythe.
