Might be a dumb question
I notice that when I plug in a USB device to my computer, a small icon called "safely remove hardware" is located to the right of the taskbar. Do I really need to load that up and disable the hardware before removing my USB device like my card reader or I can just ignore it and take out my USB card reader?
Win 2K was picky about that. WinXP no problems as long as you do as Valex said
I'd be safe and do all the clickies. I've heard of a lot of horror stories of people corrupting the data on their thumb drives. There's going to be that one time that you'll wish you did.
The official rule is that if your flash/drive is FAT32 formatted (most flash drives, unless you reformat them), you don't have to click anything. If it is NTFS, then you should. I don't do it either, most of the time, and I don't have any problems.
I use to just pull it out. That was until I got corrupted images/pics. Now I do the remove hardware, and I do not get corrupted pics. I think that explorer.exe still is using some files, or will not close some files. When you pull it out, sometimes data corrupting can happen..IMO
I have also had problems with corruption on my old USB card reader if I did not use the remove hardware safely option. Of course, I usually did my copy or whatever and then wanted to instantly remove it. I am sure if you let it sit long enough Windows will "release the hold" of the files.
