micro atx nforce SATA exists?
sxotty
I want a micro atx mboard based on nforce 2 with SATA does such a board exist or will I be forced to try the via kt400 chipset instead?
Thx..
Scott
I did a bunch of searching, Pricewatch, Bizrate, Pricegrabber, etc, etc, and could not find any NForce MATX boards at all. The only KT400 w/SATA I did find was a DFI, I believe.
Maybe someone makes them, but good luck finding one.
I want to get one for a homemade SFF.
There is actually tons of nforce2 mATX boards, just none with the mcp-t and SATA, yet I have found one finally..
Biostar M7NBA, unfortunately it is part of a SFF PC and they do not sell the board by itself...
I have actually founf one with the mcp southbridge but I want dolby encoding so I can plug it into a home entertainment center...
Here are nforce mATX with IGP at newegg
7
newegg IGP
There is one there with ultra 400 chipset as well.
You can find them on pricewatch as well by searching micro atx nforce
Have never found a Matx Nforce2 with sata, and i've been looking a long time. A seperate pci card will be in order. If you want the mcp-t southbridge (soundstorm) then you'll be looking for the shuttle MN31N.
If you have trouble finding one, i have two that are almost new that i would sell for dirt cheap if you're interested. They don't come with the spdif brackets but the one off the shuttle NF2 SFF works perfectly fine with it. There are other brand name spdif brackets that would work also (i have the merchants bookmarked btw)
Well I won't need the actual board until January or thereabouts, so perhaps by then a new one willl appear. Or maybe someone will sell the biostar, or more likely I wil just have to do as you say and fork over for a SATA card...
Anyway thx for the info.
MSI recentely announced a new board that may be just what you're looking for:
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=619
Chipset
• nVIDIA® nForce2 IGP Chipset
- FSB @266/333 MHz
- AGP 8X and PCI Advanced high performance memory controller
- Integrated graphics controller
• nVIDIA® nForce2 MCP RAID Chipset
- Integrated Faster Ethernet MAC
- Integrated Hardware Sound Blaster/Direct Sound AC97 audio
- Ultra DMA 66/100/133 master mode PCI EIDE controller
- Supports USB 2.0
- Integrated SATA Interface
I have a western digital raptor which is SATA and sorry it is much much better than IDE.
Thanks for the heads up on hte MSI board but I want an MCP-T southbridge so I get dolby digital encoding to hook up to a home entertainment center.
An idea since you'll be waiting till january to build but yet insist on Nforce2/MCP-T, browse newegg refurbs till you hit the perfect refurb deal. Test the mobo immedietely to make sure it works, then pack it away till you buy the rest of the parts.
The reason for my idea you ask? Well, theres a chance that a decent working, hardly used NF2 Matx MCP-T mobo will be a rarity come next year. Heck put my name in your buddy list since i may still have one of my three MN31N's next year and i'd swing ya a sweet deal.
Edit: here are some SPDIF bracket deals and resources to bookmark:
http://www.epanorama.net/documents/audio/spdif.html
http://www.censuspc.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=C&Category_Code=MBA001
http://shop.soyousa.com/customer/product.php?productid=293&cat=12&page=1
