memory clock speed
4LC4PON3
DERP!
i just bought a HIS 4850 found here: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161244
my problem is when i run a game the core goes up to 650 as its supossed to but the memory clock stays at 1000mhz. im running dual monitors. on the second monitor i got GPU-Z and rivatuner running.
looking for any help
my PC isnt the best
dualcore 4450e, 3gb of ram, his 4850, antec earthwatts 430, 640gb sata HD,
That isn't an error. The memory is running at 1000 MHz, which is 2000 mega-transfers per clock with DDR memory. The clock speed is not really 2000 MHz.
Some ATI cards don't scale the memory clock between idle and load. I imagine you're confused because your memory clock stays the same at idle, but your GPU clock goes down, right?
