mayakindaguy
- Jan 28, 2004
Im just curious but if my memory is running in dual channel and I have it overclocked at 220MHZ then shouldn't I theoretically be getting a memory bandwith of 7.04GB/s?
But why is it when i benched it on Sandra I'm only like 5GB/s?
Shouldn't stock PC3200 be doing 6.4GB/s?
Oh, by the way I have it overclocked synchroneously with the cpu at 1:1 for better stability, though its making my RAM timings really loose at 3-4-4-8. I'm using the ASUS noob overclock utility that gets my 3.0 up to 3.3 at 10% overclock. I can do 3.5 manually by lowering memory bandwith and getting a 5:4 ratio, but it won't run completely stable on 3D app software like Maya, but it may also be unstable because of the ram where the CAS was lowered from 3 to 2.5.
Well I guess I've digressed enough.
Any opinions, help and suggestions MUC[H] appreciated.
