Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
basically you start the program, an Icon will appear in the tray next to the clock bottom right, rightclick and a popup will appear > dashboard and settings > General > check when MBM starts, open dashboard as well > other various options, up to you > Go to Temperatures > select sensor 1 and then from the drop down list select a sensor, see if it works > repeat with sensor 2
if the first sensor is hotter then the 2nd its likely the CPU
might find the Tray and OSD valuable
OSD settings > enable OSD > select color type and location
after every change the Apply button will turn red
you need to click that
good luck
there is a list at the website for compatible mobos\chipsets
Sorry, the mobo in question is in the system I built a few days ago, the ASUS board, A7N8X-E Deluxe. Its in the list, but I only read zero for the diode. I cannot tell whats what.
its pretty much trial and error with the drop down sensor list
if it dosent work try another one, if you suspect a glitch, Alex runs his own forum (last I checked)
a quick search for the mobo would likely reveal some leads
if not then Alex answers when he can
