MB for q6600?
Had a q6600 fall into my lap, not really sure if it's worth it to build a system around it, all I would really need is a mb and some ram.
Any recommendations on some decent mb's that would provide good performance and mild overclocking?
Thanks, I was wondering why so few 775 mb's were listed. I know it's a little old but I figured it might be worth it to just pick up a cheap mb and build a simple system around it. I'm not in a rush so if something pops up in the next little while, I might try it but we'll see.
Its cheaper to build on newer sockets. More choices in mobos means more competition.. which means lower prices for the consumer. Also, DDR3 is muuuuuch cheaper than DDR2.
And a newer CPU will do things more efficiently.. even the cheap low end quads will outpace the q6600. I would sell the q6600 and look into building a budget setup if it were my money.
Check ebay around for used but nice P35/P45/X38/X48 motherboards (something from Asus or Gigabyte). P35/X38 uses DDR2, the other two use DDR3. Keep this in mind if you find that either DDR2 or DDR3 is cheaper for you.
Not sure if it will be worth it to you, but sounds like something random/fun to tinker with.
I used an Abit IP-35 Pro for my Intel E6400... fun times. Was able to do a 400MHz bus speed no problem @ 1.3750v (1600MHz FSB). You should be able to do the same with a Q6600 and get 3.6GHz easy if you got a G0 stepping of that chip (and have a decent air cooler).
It's funny how I haven't messed with that stuff since 2007 but still remember it all like the back of my hand.
EDIT: I don't think I'd pay over $45 for a board. It's not worth it otherwise imo. Check out/ask the FS/FT section of [H] too.
Buy used... seriously. After dealing with a really poor MSI motherboard that would barely let me raise the CPU (G0 Q6600) clock by 100mhz, I went to a (used) Gigabyte P45 board and upgraded to a (used) megahalem cooler that allowed me to raise the clocks up to 3.8ghz stable. I think, all in all, I spent around 100 dollars.
a lot of people tried talking me into upgrading to newer hardware, but honetly... it was cheap, gave me the chance to clean out my case, re-run all my cables and start fresh. The system runs like a champ and honestly see absolutely no reason to upgrade anytime soon outside of a GPU or maybe even a little extra RAM. The machine runs pretty much anything I throw at it without too much of an issue.
I can pretty much guarantee that you can find a highend LGA775 mobo for dirt cheap on craigslist and hardware forums
I picked up an Asus P5E-Deluxe and flashed it to a Rampage Formula bios.
Got it for only $120 on ebay, around 4 years ago.
Cranked my Q6600 up to 3.6ghz @ 1.33v and havent touched it since. Paired with crossfired 4890's it has definitely lasted me long enough. Never breaks ~55*C on an H50 as intake w/ medium speed fans (1300rpm) even after hours of gaming.
I am only barely feeling the need to upgrade, as I want to get a 27" 1440p monitor.
I would try to get something with DDR3 memory though, as you can upgrade the ram and max out the sata2 controller with a sata3 ssd. :D
Also, lap both your CPU and cooler base to get temps really good. I shaved 5*C off my load temps and at least 2 or 3 off idle.
Just a quick update, found a p5q for pretty cheap. Not planning on oc'ing it but maybe with a good cooler I can crank it up a bit :D
