There's also the P-series, which are derived from the Parhelia and hence have some more impressive specs. You might even be able to play some of the more recent games on itScourggeFX said:Bandwidth was quite limited on the G550. I couldn't get it to do 1280x1024x32 on 2 monitors, always had to back down to a lower resolution or use 16-bit colors (ugh).
For one monitor, it is fine.
Elledan said:...DVI usually is easier to implement (correctly) than VGA output, although cheap components and boneheaded designs can screw up things here as well.
Once noise or any other kind of distortion gets into the signal, no amount of digital transmission is going to improve it. If the layout of the traces on the PCB allows for such interference to be picked up, or the manufacturer decided to save some money on supporting components (caps, to name one infamous example) so that noise isn't suppressed as well as it could be, image quality is going to suffer.perplex said:okey dokey that's what i thought. so even though a cheap card is DVI, digital, technically "perfect" because of the cheap components its not quite as good as a higher quality card DVI out?![]()
Elledan said:I'm using a G550 right now, connected to two 17" CRTs, each set to 1152X864@75Hz.
As far as I'm able to determine, the image quality is absolutely perfect, both in terms of colours as in sharpness.
ScourggeFX said:I couldn't get it to do 1280x1024x32 on 2 monitors, always had to back down to a lower resolution or use 16-bit colors (ugh)..
