matching block for Quadro FX 5600
OH23
im looking for a matching water block for my Quadro FX 5600
couldnt find anything compatible for this card.
can anyone help me with this and tell me where can i get this kind of block?
thanks
Man, that is a tall order. Not normally seen as a water cooled graphics card, but I don't see why Nvidia wouldn't use their standard hole mount setup they used for the 8800 series, but a quick search turned up nothing on the subject. Your best bet would be to find out the hole pattern for your card. Is it a four hole pass-through? You might be able to use a universal water block such as a DD Maze4 / Maze 5 or D-Tek GFX2 which comes with both Nvidia and ATI mounts. Can you take pics of the card without the stock heatsink on it?
MrE - thanks for your reply.
As soon as i get the card' i'll take a pic without the stock heatsink
if this look like this, its the same as 88gtx so holes will be 58,5x58,5 (all other NV cards 7,8,9 serieshas 53,5x53,5 except g80 cards)
so d-tek gfx or mcw60 with g80 mounring will be fits
