make a fan controller?
jaibot
hey,
so i have 4 high speed panaflows on my rad and they are extremely loud. They have succeeded in driving me, my family, and friends on vent absolutely nuts.
So i would like to build a fan controller to keep the noise under load.
I dont know much about electricity, etc, but from what i can gather resistors resist voltage depending on how many amps are going through them and diodes always resist a set amount of volts. Therefore i think i would think that i would like to use diodes in my controller.I would like three settings, full 12v, maybe a 9v, and maybe a 7v or 6v. I guess i could make my own switch, or maybe get one, but i am not sure what to look at.
Furthermore i was wondering if heat will be an issue. THe diodes will be resisting 1v (about) each, with 2a going through them. How much heat will this generate, and should i make heatsinks for the doides.
In summary
-brush me up on specifics of resistors, etc
-what to do for a switch
-how much heat will diodes give off
thanks in advance for your help, it is much appreciated
You can buy them for about, or not much more than the parts will cost you.
Check out: http://www.frozencpu.com/
Unless I'm mistaken, a basic one uses just switches and supplies the voltages already present on a molex. Three settings, off, 7v, 12v...no resistors or diodes necessary.
If you just wanted to reduce voltage to the fans install a resistor in line on the fan cable, obviously its the easiest way but non adjustable,
just buy a handy fan controller like the one I just got for my project, its cheap and better quality that the average person could ever make.
http://hardforum.com/showthread.php?t=1363417
Could you not just switch the wires from the molex adater if you wanted no control over fans speeds?
