madness...
xirokx
Hi,
I overclocked my pc as per the settings in my sig, it was prime stable for 15hrs +
Now I just realised my RAM wasn't running to the overclock so I went into the BIOS and noticed it had changed to run slower then what I found the max overclocking to be whilst testing...
As I have a DFI board I simply reloaded the overclocking bios and manually checked all settings were correct..Which they were, once I had reloaded the overclocking bios....
When I booted I couldnt even get into windows...Yet it primed stable for 15hrs+ I ran 2 instances of prime95 and it was working perfectly fine before..
Im thinking my Overclock is no longer stable? what do you think? How can it run for 3 - 4 weeks stable then stop overnight?
Please advise...
Thanks in advance..
It's possible that your RAM was running slower for the last 3-4 weeks... Then when you tried to increase it... well, you know.
Unless I'm reading that wrong.
RAM was running at 265mhz per stick as thats what I found was 5mhz below the maximum overclock when I was testing it initally...
