Hi,
I have just put together a brand new system (specs below) with a fresh install of WinXP Pro, SP2. but i keep getting one of two things: this BSOD, or just lock-ups. Both happen at completely random points. Sometimes after the machine has been on for hours, sometimes when it just gets past the "welcome" screen after boot.
I've checked around, but no real solutions can be found. MS's KB article doesn't say much on how to fix it.
any ideas? thanks in advance...
Specs:
Asus A8N-E revision 2, bios 1005. (drivers from Asus CD, probably 6.53?? I have also tried the 6.66 drivers and they were very unstable)
AMD X2 4400+
2GB (1GB stick x 2) Corsair Value Select VS1GB400C3 (in first and third DIMM slots, A1 and B1)
BFG 7800GTX PCI-E (78.03 drivers from nvidia)
Antec TruePower 550 EPS12V SSI Server-rated PSU
Maxtor DiamondMax 10 SATA 200gb (on 1st SATA channel)
Creative 52x CD-ROM (IDE Primary master)
Plextor 716AL DVD/CD burner (IDE, Secondary master)
Plextor 16/10/40A CD burner (IDE, Secondary slave)
Floppy drive
2 case fans + 1 CPU fan (AMD retail box HSF)
Windows XP Pro, SP2 (have also tried it with XP x64 Edition for a bit)
-everything is running at stock speeds, no overclocking.
-I have left the 1005 bios, as that seems to be the most stable which people say.
-Windows is completely updated (w/ SP2).
-I have not installed the nvidia IDE drivers.
-temps according to the bios are between 35-39 degrees (celcius).
-everything on auto in the bios except for ram which i bumped up to 2.75v.
-ran memtest86+ for about 2 hours, found no erros
-ran the diagnostic util for my Maxtor hdd, found no errors
Code:
MACHINE_CHECK_EXCEPTION
STOP: 0x0000009C
Specs:
AMD X2 4400+
Floppy drive
