Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If you want outstanding sound quality for your desktop and pickup a pair of this ones DSM1, and want to use its spdif input, how can you get both plugged having just one spdif output on your pc's onboard sound device?
if I'm understanding you right, you're asking how it works if you purchase two DSM1's and want stereo output?
theres a configuration switch on the DSM1 that sets which channel its supposed to be, you simply daisy chain the DSM1's together and put your computer's output on the input side of said chain, set the switches, and it works out
why it works:
a S/PDIF signal has stereo data (well, can have, it may also be mono of course; these speakers don't do AC-3 or DTS so thats unrelated), you're simply telling the decoder in the speaker which "half" of that signal to decode and use
