lurker-drop
- Oct 31, 2003
i made it rhyme.. nice... anyway
Ok I have a vantec aeroflow on a xp2200+ (1.8Ghz) which i overclocked to 1.9Ghz, vcore 1.625
It was running about 35C idle using the vantec paste that the aeroflow came with...
I figured why not try some artic silver 5? And so I did, i popped it open, clean off the vantec paste, layed a thin neat layer for the as5... and behold my computer started up at around 24C and ended up around 26C idle after an hour...
I was impressed but the tempatures started to climb back up to 35C over a day or two, now it is even higher... at 38C idle...
Recently I upped the Vcore to 1.65 and it jumped up to 40C idle..
Now I just popped the HSF open again and checked the paste, most of the as5 was 'melted' away or something, so I figured thats the problem, so I wiped it clean, applied a little more than last time, and I'm getting the same results...
What's up? I'd figured the as5 should atleast give me a degrees or two lower than the vantec paste... but its giving me higher temps.. why was it so low for a day and then it disappeared?
