--- Opening Log file [April 28 14:12:26 UTC]
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.34
[url]http://folding.stanford.edu[/url]
Launch directory: D:\fah\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\SMP
Executable: D:\fah\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\FAH.exe
Arguments: -oneunit -forceasm -smp -advmethods -verbosity 9
[14:12:26] - Ask before connecting: No
[14:12:26] - User name: Hijacker (Team 33)
[14:12:26] - User ID: 7824BFFD6ABA5705
[14:12:26] - Machine ID: 2
[14:12:26]
[14:12:26] Work directory not found. Creating...
[14:12:26] Could not open work queue, generating new queue...
[14:12:26] - Preparing to get new work unit...
[14:12:26] - Autosending finished units... [April 28 14:12:26 UTC]
[14:12:26] Cleaning up work directory
[14:12:26] Trying to send all finished work units
[14:12:26] + No unsent completed units remaining.
[14:12:26] - Autosend completed
[14:12:26] + Attempting to get work packet
[14:12:26] Passkey found
[14:12:26] - Will indicate memory of 2047 MB
[14:12:26] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 2, Stepping: 5
[14:12:26] - Connecting to assignment server
[14:12:26] Connecting to [url]http://assign.stanford.edu:8080/[/url]
[14:12:27] Posted data.
[14:12:27] Initial: 8F80; - Successful: assigned to (128.143.199.96).
[14:12:27] + News From Folding@Home: Welcome to Folding@Home
[14:12:27] Loaded queue successfully.
[14:12:27] Sent data
[14:12:27] Connecting to [url]http://128.143.199.96:8080/[/url]
[14:12:28] Posted data.
[14:12:28] Initial: 0000; - Receiving payload (expected size: 1769202)
[14:12:30] - Downloaded at ~863 kB/s
[14:12:30] - Averaged speed for that direction ~863 kB/s
[14:12:30] + Received work.
[14:12:30] + Closed connections
[14:12:30]
[14:12:30] + Processing work unit
[14:12:30] Core required: FahCore_a3.exe
[14:12:30] Core found.
[14:12:30] Working on queue slot 01 [April 28 14:12:30 UTC]
[14:12:30] + Working ...
[14:12:30] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 4 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 876 -version 634'
[14:12:30]
[14:12:30] *------------------------------*
[14:12:30] Folding@Home Gromacs SMP Core
[14:12:30] Version 2.27 (Dec. 15, 2010)
[14:12:30]
[14:12:30] Preparing to commence simulation
[14:12:30] - Assembly optimizations manually forced on.
[14:12:30] - Not checking prior termination.
[14:12:31] - Expanded 1768690 -> 1957708 (decompressed 110.6 percent)
[14:12:31] Called DecompressByteArray: compressed_data_size=1768690 data_size=1957708, decompressed_data_size=1957708 diff=0
[14:12:31] - Digital signature verified
[14:12:31]
[14:12:31] Project: 6972 (Run 0, Clone 61, Gen 41)
[14:12:31]
[14:12:31] Assembly optimizations on if available.
[14:12:31] Entering M.D.
[14:12:37] Mapping NT from 4 to 4
[14:12:38] Completed 0 out of 500000 steps (0%)
[14:38:16] Completed 5000 out of 500000 steps (1%)
[15:03:45] Completed 10000 out of 500000 steps (2%)
[09:49:30] --------------------------------------------------
[09:49:30] FAH GPU Tracker v3.52 Startup
[09:49:30] Detected OS: Windows XP
[09:49:34] Detected CPU: Intel(R) Xeon(TM) CPU 3.06GHz
[09:49:34] 0 Cores, 0 Threads, 3,056 MHz
[09:49:34] CPU detection failed, using defaults
[09:49:35] Creating client folders...
[09:49:35] Downloading FAH clients...
[09:49:58] Extracting clients...
[09:49:59] Clients extracted successfully
[09:49:59] Setting up clients...
[09:49:59] Client setup completed successfully
[09:49:59] Setting up client configs...
[09:49:59] Setting up GPU0 client config
[09:50:00] Setting up GPU1 client config
[09:50:00] Setting up GPU2 client config
[09:50:00] Setting up GPU3 client config
[09:50:00] Setting up GPU4 client config
[09:50:01] Setting up GPU5 client config
[09:50:01] Setting up GPU6 client config
[09:50:01] Setting up GPU7 client config
[09:50:01] Setting up CPU client config
[09:50:02] Setting up SMP client config
[09:50:02] Client configs generated successfully
[09:50:02] Cleaning up client folders...
[09:50:02] Initial setup complete
[09:50:37] Applied new config settings
[09:50:51] Starting SMP
[09:50:51] Updated SMP config, restarting client
[09:50:51] Started new WU on SMP
[10:10:32] Error stopping SMP safely, code=127
[10:10:32] Stopped SMP
[10:10:45] Applied new config settings
[10:10:46] Starting SMP
[10:10:46] Resumed existing WU on SMP
[10:10:52] Error stopping SMP safely, code=127
[10:10:52] Stopped SMP
[10:11:13] Tracker exiting
[10:12:03] --------------------------------------------------
[10:12:03] FAH GPU Tracker v3.52 Startup
[10:12:03] Detected OS: Windows XP
[10:12:08] Detected CPU: Intel(R) Xeon(TM) CPU 3.06GHz
[10:12:08] 0 Cores, 0 Threads, 3,056 MHz
[10:12:08] CPU detection failed, using defaults
[10:12:20] Deleted WU on SMP
[10:12:26] Starting SMP
[10:12:26] Started new WU on SMP
Yeah, that has HT so four threads is correct.Intel Xeon 3.06 Prestonia 3.06GHz 512KB L2 Cache 1MB L3 Cache Socket 604 Processor BX80532KE3066E
