Low 3Dmark Score w/ 9800XT
Surge
AMD64 3200+
Shuttle FN85 (SFF system) mobo
ASUS A9800XT
1GB Corsair XMS PC3200LL @ 2-3-2-6
120GB Maxtor ATA133 HDD
SB Audigy 2 ZS
score: 6640
All BIOS and drivers are up to date, yet still getting rediculously low scores. I used to get 10,000s before most recent format but I havn't been able to even scratch the 8000 mark since no matter how I config the system.
Not sure if my temps may be affecting performance but I get no artifacts, and my shuttle has a blowhole keeping it at a stable 40C idle and 55C under full load. Side panel has also been mod'd for better exhaust for the vid card.
Surge said:
AMD64 3200+
ASUS A9800XT
SB Audigy 2 ZS
score: 6640
I'm really get sick of all of these "Is my 3dMark score low?" questions!! :p
You DID NOT get 10,000 with 3dmark2003! That about where you should be in the 6000 range. I cant even imagine you getting close to 8000.
I wish on 3dMark2003, they had the links for 3d accelerater & CPU comparison like they do under 3dMark2001. So you know exactly where you stand in a percentile rank for your sytem.
You talking about 3d mark 03 or 01? Cuz I had 9800 Pro and I only got 5300 with it. So you should be getting about ~7000
My 6800GT does 11k, your card cant do 11k. Probably only half.
thanks guys.. i was probably getting confused with 2001 version... my bad ;)
I get 7200 With my System so id say your about on par
considering it really only tests the videocard
